Surface touch screen works with pen, but not my finger
2014-08-23T04:09:38+00:00
I can use my pen with the touch screen, but my Surface doesn't respond when I use my finger. What is the issue?
I have already restarted twice. I don't think it's an update problem because I just downloaded updates two days ago.
Surface | Surface Earbuds | Touch and gestures
2014-08-26T20:59:57+00:00
Hi there,
Thank you for replying back.
If none of the solutions works, you also have the options of contacting our support or doing a self-service request here.
Best Regards,
Clare
2014-08-23T23:37:05+00:00
Hi uteweatherman
Thank you for reaching out to us on the community forum and thank you for your question. I understand you are having finger input issues on your Pro 3 device. I'm here to help.
I'd like to know more details:
  • You said the Pro pen works fine but it doesn't respond to your fingers, correct? Are you using the finger and the pen at the same time?
When you bring Surface Pen close to the touchscreen, a point appears on the screen and the screen ignores other input such as your hand resting on the screen. You can relax and write or draw as you would with a regular pen and paper.
  • Do you have all updates? Just to be sure, you can see the detailed update information for Pro3 here.****
If you still have issues with touch, I'd suggest the following:
Please reply back and let us know.
Best Regards,
Clare
15 additional answers
    2014-10-05T21:42:59+00:00
    I do not use pen and finger together.one at a time.
    And yes I install all updates after firmware update this happened.
    And I try every 5 solutions but nothing happens.
    2014-10-06T18:29:16+00:00
    Hi SamJahadian,
    If none of the solutions works, please contact our support or open a self-service request here.
    Best Regards,
    Clare
    2014-10-06T21:09:06+00:00
    Hi clare
    Thanks for replying back.
    Link to self service request required password.
    How should I obtain that.
