Surface touch screen works with pen, but not my finger
2014-08-23T04:09:38+00:00
I can use my pen with the touch screen, but my Surface doesn't respond when I use my finger. What is the issue?
I have already restarted twice. I don't think it's an update problem because I just downloaded updates two days ago.
Surface | Surface Earbuds | Touch and gestures
2014-08-26T20:59:57+00:00
Hi there,
Thank you for replying back.
If none of the solutions works, you also have the options of contacting our support or doing a self-service request here.
Best Regards,
Clare
2014-08-23T23:37:05+00:00
Hi uteweatherman
Thank you for reaching out to us on the community forum and thank you for your question. I understand you are having finger input issues on your Pro 3 device. I'm here to help.
I'd like to know more details:
  • You said the Pro pen works fine but it doesn't respond to your fingers, correct? Are you using the finger and the pen at the same time?
When you bring Surface Pen close to the touchscreen, a point appears on the screen and the screen ignores other input such as your hand resting on the screen. You can relax and write or draw as you would with a regular pen and paper.
  • Do you have all updates? Just to be sure, you can see the detailed update information for Pro3 here.****
If you still have issues with touch, I'd suggest the following:
Please reply back and let us know.
Best Regards,
Clare
15 additional answers
    2014-09-27T21:22:08+00:00
    and how is it possible that win logo touch works fine but screen touch stop responding?
    the logo is a separate button, its not part of the touch screen.
    2014-09-28T17:10:55+00:00
    thank you
    and do you know how pen works but not finger?
    2014-09-28T18:30:36+00:00
    thank you
    If I did, I would've mentioned it.
