Hi there,
Thank you for replying back.
If none of the solutions works, you also have the options of contacting our support or doing a self-service request here.
Best Regards,
Clare
I can use my pen with the touch screen, but my Surface doesn't respond when I use my finger. What is the issue?
I have already restarted twice. I don't think it's an update problem because I just downloaded updates two days ago.
Hi uteweatherman,
Thank you for reaching out to us on the community forum and thank you for your question. I understand you are having finger input issues on your Pro 3 device. I'm here to help.
I'd like to know more details:
When you bring Surface Pen close to the touchscreen, a point appears on the screen and the screen ignores other input such as your hand resting on the screen. You can relax and write or draw as you would with a regular pen and paper.
If you still have issues with touch, I'd suggest the following:
Please reply back and let us know.
Best Regards,
Clare
Hi
I bought a surface pro 3 3 weeks ago.at first everything works fine , but after firmware update touchscreen stop responding.
My pen works fine and when I touch win logo at the right side with my finger it works fine but when I touch the screen nothing happens.
I tried every 5 solutions that Microsoft offered but nothing happens.
in my country I do not have access to Microsoft support center so it means there is no guarantee.
So is it possible that I downgrade to previous firmware?
and how is it possible that win logo touch works fine but screen touch stop responding?
(there is no hardware problem shows in dev manager)
Thank you. I took it to the Microsoft Store and they gave me a replacement.
yes, the Pro pen works fine, but doesn't respond to my fingers. I'm not using the pen and finger at the same time. I can't even use my finger when swiping the unlock screen. And yes, I do have all the updates. I'm going to take it to the Microsoft store tomorrow.
