Thanks for the prompt feedback. But the tool that you link to has a number of options. Do you want me to use it to update to the "Windows 10 10 November 2019" version? I think I'm already past that: I'm on the Windows Insider Fast Track, currently running version 2004 (build 19041.1). I didn't think that reverting to an earlier version was possible without doing a clean install from installation media....
Surface Pro X display brightness issue.
I'm having an odd experience with the screen brightness of my SPX. Here's the sequence:
- Turn on the SPX to wake it from sleep. The screen appears to be at about 60% brightness.
- Press F7 (increase brightness). The screen brightness widget appears briefly, showing 100% brightness. The screen brightness doesn't change.
- Open Settings, navigate to System ->Display page. The Display brightness slider is at 100%. (Change brightness automatically is unchecked.)
- Click the Display brightness slider at about the 80% mark. The screen immediately brightens (confirming that it was well below 100%).
- Click the slider at the 100% mark. The screen brightens to 100%.
This sequence is the only way I can get 100% brightness after the SPX has been in sleep mode. Thoughts?
[Note: this is with the SPX connected to power. I haven't tried it on battery. The advanced power settings are standard Balanced. The system is on Windows Insider Fast Track, and is up-to-date.]
2019-12-11T21:03:26+00:00 -
2019-12-11T21:15:41+00:00 I am also on the same insider build 19041.1, experiencing the same behavior for a couple of insider flights now. I am not sure whether the non-insider version (surface pro x out of the box) had the same issue. maybe someone else with a surface pro x that is not on the insider track could confirm?
I have filed a problem report on feedback hub as well.
2019-12-12T00:48:07+00:00 HelloGeoffreyMArnold ,
Thank you for reaching out Microsoft Community. Please choose the second option under Create windows 10 installation media and click download tool now.
Please keep us posted.
Regards,
Jonas_T
2019-12-12T14:55:13+00:00 -
2019-12-14T23:23:43+00:00 Hello GeoffreyMArnold ,
Thank you for reaching out Microsoft Community. We really appreciate all the efforts that you did just to possibly resolve the issue.
Lets try this :
Fresh Start lets you perform a clean reinstallation and update of Windows while keeping your personal data and most Windows settings intact. In some cases, a clean installation may improve your device's startup and shutdown experience, memory usage, Microsoft Store apps performance, browsing experience, and battery life.
- To use Fresh Start, select Start Windows logo Start button > Settings Gear-shaped Settings icon > Update & security Circular arrows Sync icon > Windows Defender > Device performance & health. Under Fresh Start, select Additional info > Get Started
Regards,
Jonas_T
