I have the exact same issue, except it's a Bose Soundlink II speaker with my brand new Surface 3. I don't have this problem at all with my Amazon Kindle Fire, I just turn on the speaker, it keeps its connection, and I'm playing music Easy Peasy as it should be.
With my new Surface 3, after the machine has been in sleep mode or turned off, I need to delete the Bose speaker from the list of paired devices, then re-pair it to listen to music, frustrating when I don't have this issue at all with other devices.
Bose Soundlink speaker loses connection
Surface | Surface Headphones | Setup and pairing | Windows
Hello SdSurfer,
Thank you for posting to the Community. I am sorry to hear about the issue you are experiencing with your Bluetooth device when paired with your newly purchased Surface Pro 3. Please rest assured, I am here to help.
I understand you have been able to fully use the Bluetooth device with the Surface Pro 3, however the issue arises solely after your Surface Pro 3 returns from Sleep mode or turned off.
This can occur when the system automatically turns off your Bluetooth device to save power when it detects that you've entered into idle mode.
Please give the steps below a try and see if it resolves your issue in particular.
First make sure your device has the latest updatesfully installed.
Then:
- Open Device Manager
- Expand the "Bluetooth" options.
- From the list double click the "Marvel AVASTART Bluetooth Radio Adapter".
- Click the "Power Management" tab.
- Uncheck the check box "Allow the computer to turn off this device to save power."
- Click the "Save" button to save the settings.
Ultimately, you can also click here for steps on how to troubleshoot inconsistencies with Bluetooth devices.
Please try the steps provided above and let us know how it all worked out for you.
6 additional answers
2016-05-17T17:59:16+00:00 Hello AaronHoffman,
Thank you for reaching out to the Surface community. When you go into Device Manager, do you see the Marvell AVASTAR Bluetooth Radio Adapter under Bluetooth?
Best Regards,
2016-05-17T20:31:23+00:00 I apologize, I wasn't aware this was a Surface forum specifically. I am actually running Windows 10 on a Dell Desktop. I am having the same issue with by Bose speakers however, and the drivers are up to date, so I thought it might be related.
2016-05-20T20:05:57+00:00 The Bose Soundlink Mini II speaker has an auto-off feature that is enabled by default. You can disable it by pressing the bluetooth and [+] buttons simultaneously for a few seconds
more info:
