Surface Pro 3 external monitor / display port issues
2014-09-04T17:19:34+00:00
I know many people have been having issues with external monitors and the displayport connections on the Surface Pro 3 and Surface dock.  I've been having some issues too, and thought I'd share my config / workarounds in case it helps. I believe the issue is fundamentally with the Surface video drivers getting confused, not the docking station.
My explicit questions are: Is there an easy way to force it to detect new displays?  Anybody have any other suggestions on how to resolve this?  Is there some way to open a formal technical ticket with MS?
My hardware: Surface Pro 3 i7, 256 GB; Surface docking station, 2 HP Z24i displays (1920x1200 resolution each), StarTech Mini DisplayPort 1.2 to Triple Head DisplayPort MST Hub (StarTech PN# MSTMDP123DP)
It's setup as follows: Mini DisplayPort MST Hub plugged into back of docking station, HP monitors plugged into ports 1 and 2 of the hub.
I've had this setup running for about 2 weeks. At first I couldn't get it working, but with the last firmware update in mid August it started working fine.
HOWEVER, just this week I've had issues where I can't get the Surface to detect the displays / output to them when I first plug in to the dock in the morning OR sometimes when it's waking up from going to sleep (like at lunchtime). No amount of fiddling / plugging / unplugging things seems to consistently fix it.  The 'Detect' button in the Screen Resolution window doesn't help.  Doing a shutdown / restart of the Surface also doesn't consistently work. Note that when the Surface gets like this, even plugging the Hub directly into the mini display port on the Surface itself (with it not docked) won't work.
The reason I believe this is a Surface / Windows issues is that when it gets into this state, within the screen resolution settings in windows it often thinks that there is another active display plugged in and will act as such (e.g. lets me extend or duplicate the desktop) - even if I have the surface completely undocked, not plugged into anything. Specifically it says it is a "Display device on: Mobile PC Display" with a resolution lower than 1024 x 768.  See pic below.  This state often survives through a reboot of the Surface.
The general process I usually get to work after a couple tries:
-Use Windows-P keys to set the surface to use only the internal display
-Shutdown the surface and undock
-Unplug the dock and hub
-Plug hub back in
-Power Surface back up while undocked and login
-Dock surface
-Plug dock back in
-I'll know it works at this point because the displays will automatically come on (no need to use windows-P key to toggle them)
NOTE TO FORUM MODS:
Before you reply with your standard questions, know that I've already done all the normal things, including shutdown, check all cables, all updates installed, run the hardware and devices troubleshooter.  I've also checked related threads, such as: http://answers.microsoft.com/en-us/surface/forum/surfpro3-surfdevice/external-display-flicker/1e2b9154-0533-4137-880f-55a90d2d6659?page=1&tm=1409850909719 (Note I've never had an issue with flicker) and http://www.surfaceforums.net/threads/mini-displayport-on-new-docking-station-doesnt-work.10577/ (This isn't an active vs. passive adapter thing.)  Once I get it working it works just fine until the surface undocks or reboots.  It's clearly an issue with Windows / Surface not properly detecting displays.
    2015-01-16T08:07:31+00:00
    To everyone in this thread, I've logged a support call with the Microsoft Business Surface Support team which has been escalated. I'll post an update if I hear anything.
    In the mean time it may be worth trying the newly released January updates for the Surface Pro 3. They will hit Windows Update in the various regions shortly.
    • Surface Pro UEFI update (v3.11.450.0) adds support for updated HD Graphics Family driver.
    • HD Graphics Family driver update (v10.18.14.4029) enhances display stability and performance, improves user experience when using Miracast adapters. Improves compatibility with DisplayPort monitors and daisy chaining.
    2015-01-16T14:48:36+00:00
    I ditched the Startech splitter and tried one from EVGA at this link: http://www.evga.com/Products/Product.aspx?pn=200-DP-1301-L1
    It has worked perfectly.  I mean not a single issue. Whether from a cold start, from sleep, from just removing and replacing the surface into the dock, everything works just fine.
    This hub only uses standard DP and thus you will need a converter from Mini-DP to DP for connecting the surface to the hub.
    Good luck.
    Hi Nicholas,  Are you able to extend across 3 external displays?
    2015-01-16T20:00:19+00:00
    Since I've updated it appears that my monitors are now working fine.  I don't want to jinx myself...but I think Microsoft may have fixed this...
    2015-01-17T13:31:39+00:00
    Hi Chalker2,
    Thank you for contributing and participating in the Microsoft Community! We appreciate the time you have taken to post this and provide all these details and workarounds. I understand you’ve been having problems getting the Surface Pro 3 to detect your external displays when waking from sleep or when you first plug it into the Docking Station. I can see how this is very inconvenient, taking into consideration all the steps you take in order to have it working again each time this happens. I’ll be glad to guide you in the right direction!
    In this case, as you mention, since you have performed most troubleshooting steps, we suggest the following:
    • Please make sure all Windows updates were applied while the Surface was on the Docking Station. This is very important.
    • Consider a Reset/Refresh
    • Contact our Technical Support Team for further options Here.
    We truly appreciate the feedback provided and contributions on this thread. I would also like to convert it into a discussion so other Community members can add their voice, solutions and expertise.
    Best Wishes,
    did you really suggest refreshing the Sruface in order to address an external monitor issue? What sort of support is this?
    2015-01-18T01:14:21+00:00
    OK so I jinxed myself.  From the Dec 30 update, my monitors were working flawlessly...then I updated the firmware on the 17th of January (Jan 15 update) and now same problems.
