Surface Pro 3 external monitor / display port issues
2014-09-04T17:19:34+00:00
I know many people have been having issues with external monitors and the displayport connections on the Surface Pro 3 and Surface dock.  I've been having some issues too, and thought I'd share my config / workarounds in case it helps. I believe the issue is fundamentally with the Surface video drivers getting confused, not the docking station.
My explicit questions are: Is there an easy way to force it to detect new displays?  Anybody have any other suggestions on how to resolve this?  Is there some way to open a formal technical ticket with MS?
My hardware: Surface Pro 3 i7, 256 GB; Surface docking station, 2 HP Z24i displays (1920x1200 resolution each), StarTech Mini DisplayPort 1.2 to Triple Head DisplayPort MST Hub (StarTech PN# MSTMDP123DP)
It's setup as follows: Mini DisplayPort MST Hub plugged into back of docking station, HP monitors plugged into ports 1 and 2 of the hub.
I've had this setup running for about 2 weeks. At first I couldn't get it working, but with the last firmware update in mid August it started working fine.
HOWEVER, just this week I've had issues where I can't get the Surface to detect the displays / output to them when I first plug in to the dock in the morning OR sometimes when it's waking up from going to sleep (like at lunchtime). No amount of fiddling / plugging / unplugging things seems to consistently fix it.  The 'Detect' button in the Screen Resolution window doesn't help.  Doing a shutdown / restart of the Surface also doesn't consistently work. Note that when the Surface gets like this, even plugging the Hub directly into the mini display port on the Surface itself (with it not docked) won't work.
The reason I believe this is a Surface / Windows issues is that when it gets into this state, within the screen resolution settings in windows it often thinks that there is another active display plugged in and will act as such (e.g. lets me extend or duplicate the desktop) - even if I have the surface completely undocked, not plugged into anything. Specifically it says it is a "Display device on: Mobile PC Display" with a resolution lower than 1024 x 768.  See pic below.  This state often survives through a reboot of the Surface.
The general process I usually get to work after a couple tries:
-Use Windows-P keys to set the surface to use only the internal display
-Shutdown the surface and undock
-Unplug the dock and hub
-Plug hub back in
-Power Surface back up while undocked and login
-Dock surface
-Plug dock back in
-I'll know it works at this point because the displays will automatically come on (no need to use windows-P key to toggle them)
NOTE TO FORUM MODS:
Before you reply with your standard questions, know that I've already done all the normal things, including shutdown, check all cables, all updates installed, run the hardware and devices troubleshooter.  I've also checked related threads, such as: http://answers.microsoft.com/en-us/surface/forum/surfpro3-surfdevice/external-display-flicker/1e2b9154-0533-4137-880f-55a90d2d6659?page=1&tm=1409850909719 (Note I've never had an issue with flicker) and http://www.surfaceforums.net/threads/mini-displayport-on-new-docking-station-doesnt-work.10577/ (This isn't an active vs. passive adapter thing.)  Once I get it working it works just fine until the surface undocks or reboots.  It's clearly an issue with Windows / Surface not properly detecting displays.
    2014-11-04T16:01:42+00:00
    Chalker2, this did the trick.
    SP3 i7. 2 Dells U2715H
    I am not using a hub, rather 2 monitors daisy chained from the dock ( dock => **** (First Monitor) => mDP (Second monitor).
    Applied all updates in the dock. Followed your steps. Worked the first time.
    I wonder if unplugging the dock from power (for over 30 seconds) is the key step here, I have read in another post that should be done.
    Thanks, you have saved me a headache and a number of wasted hours. I love my SP3, and this was a show stopper.
    2014-11-14T01:05:13+00:00
    I too have been having similar issues with my SP3 i5. I have been using the daisy chain from SP3 to Acer K272HUL and Asus PB278 (both are using DisplayPort). This configuration was working perfectly for the first 3 months with no issues at all. About 2 months I started getting the same issues as described. Monitors not detected, phantom monitors, and flickering monitors.
    I have do the same dances to get them to work but rarely is it ever stable for an entire work day. It has gotten to the point recently that it's no longer workable.
    I am convinced it MUST be the SP3/Windows driver software. Otherwise, why would it work perfectly for months? I have tried using just the dock, just the SP3 and tried the trick of connecting to the dock and SP3 ports separately. I still get the issues no matter what.
    I also tried DP to HDMI and DB DVI and that didn't resolve the issue either. And yes, different cables were tried too.
    I am NOT a happy camper with this situation.
    2014-11-18T18:11:11+00:00
    -Plug hub back in
    -Dock surface
    -Plug dock back in
    The song and dance posted above is frustratingly familiar to me.
    I'm not using an MST hub; I just have a Lenovo monitor connected via the Surface Dock mini DisplayPort.
    Haven't been able to find a common "fix" from the above list - it's usually a messed up 5-10 minute combination of those things.  Eventually I get it working again.
    I've found the most success by ensuring I power up and login to the Surface PRIOR to docking.
    If I accidentally dock while it's powered down/sleeping and/or logged off I'm almost always in for a bad start to the morning.
    I also have a third monitor connected via a USB DisplayLink adapter.  That was working fine until I added the Microsoft Wireless Display Adapter (at least that's the only system change I can think of that may have affected the DisplayLink adapter).  That issue is discussed here:
    https://answers.microsoft.com/en-us/surface/forum/surfpro3-surfdevice/surface-pro-3-not-working-with-displaylink/341175ff-f3ea-4dc9-a346-f28a09bbda58
    I've never had so many driver/firmware issues...  SP3 has been a very frustrating device in that regard.
    2014-11-18T20:56:20+00:00
    My Surface Pro 3 worked great for about a month, then the "i really don't want to completely wake up from sleep" mode kicked in.
    my monitors have never been a problem, as i use the mini dv on the docking station and on the SP3 for my dual setup.
    however, my wireless keyboard/mouse and even the touch screen does not respond to anything.
    sometimes i can see the 8.1 screen, but nothing is active, just the view, no touch screen, no mouse, no keyboard, no nothing.  Nothing i do wakes it up.  i have to manually power off the SP3, reboot (when it let's me) does not release the sleep either.  once it's powered off/on, it works.
    very frustrating when files and process were active.
    anyone?????
    2014-11-21T14:39:10+00:00
    I don't have a solution & I have given up on finding one (Vista anyone?), however I figured I would let everyone know it has been an issue since the beginning.  My SP1 has the same mini DP issue where it doesn't fully detect the external monitor on reboot and occasionally waking.  Disconnecting and reconnecting seems to work for me.  I also have the same issue occasionally with the USB and KB ports. If I wake the SP1 with the KB flipped around back, I usually have to disconnect & reconnect to get it to recognize.  I didn't connect an external monitor until earlier this year.  I wish I had done it earlier so I could attest as to whether or not it used to work, confirming an update would fix it.
