Here is whst I learned from Zoon tech support:
| <br>Patricia James-Boatner (CCC TechConnect)<br><br><br><br>May 15, 2020, 2:14:22 PM PDT<br><br><br>Good Afternoon, <br><br> <br><br>At this time there is no known issue from Zoom concerning low bandwidth. This matter sounds like it is with your network and bandwidth. Are you on a wireless network or wired? <br><br>Zoom meetings can demand significant memory and processing power from your computer. Closing other applications, ones you do not need during the session, will help Zoom run better. <br><br> <br><br>Avoid other activities that will steal bandwidth. <br><br>Don't start other bandwidth-intensive activities just before, or during, a Zoom meeting. On your Zoom device—and as much as possible, on other computers and devices that share your Internet connection—avoid: <br><br>· large downloads <br><br>· large uploads <br><br>· streaming video (e.g. Netflix, Hulu, YouTube) <br><br>· cloud backups (e.g. Carbonite, CrashPlan) <br><br>· cloud file synchronizations (e.g. OneDrive, Dropbox) <br><br>· other high-bandwidth activities <br><br> <br><br>Minimum bandwidth is 600kbps (up/down) and recommended is 1.5 Mbps (up/down). They should check their Internet bandwidth using an online speed test, such as nperf, Speedtest, or Comparitech. <br><br> <br><br>Patricia James-Boatner <br><br>CCC TechConnect Support <br><br>******@ccctechconnect.org |
