Greetings all,
I had an issue this morning where Surface couldn't find any wifi networks (when 5 were in the area) and it was connected the previous night. I solved this issue by searching windows rt for Network. Open Network Connections, find the wifi device and then disable this connection. After a minute - I re-enabled the connection and then it started to work.
Nate
Greetings all,
Greetings everyone,
If following the steps in the provided links below fail to resolve your Wi-Fi issue I encourage you to create a new thread.
You will most likely have to do a REFRESH. Most of us has had to do that. For some reason or another the driver gets corrupted. You may also do a trick that most others have done as well as long as you don't have the 8.1 Preview of Windows 8 RT installed.
That trick is to open the Control Panel and go do Device Manager. Look for the Marvel WiFi adapter and "Uninstall" the driver but "DO NOT DELETE IT". When finished, reboot the tablet and it should connect.
Hello priscillaodendaal,
Let us know.
Best regards.
Andrew,
I'm a senior consultant with Microsoft. While your answer is applicable to the type of problem I am describing, it is not a solution to what I am experiencing. I have power cycled the network infrastructure here and can still replicate the problem.
None of the other computers on the network here are experiencing the problems that the surface is. I've tried Mac OS, WIn 7, and Win 8 with various computers here. Not able to experience this problem. Surface, 100% ability to reproduce the problem.
It's is independent of the router - I've tried 3 here at home and also been able to reproduce the problem at Starbucks on whatever infrastructure they have.
Final item of note: when this happens, I am unable to turn off the wireless either through airplane mode or turning off the individual wireless item. Trying this through the command line and a reset that way does not affect the problem. Only a reboot solves it. For a while.
Eric
