wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2012-11-02T23:01:05+00:00
    Hey all,
       We're sorry to see that you are having this issue. This issue is currently under investigation, in the meantime here is a workaround, in addition to the 802.11g fix mentioned above, you can also try and disable your routers QoS setting. I have been having some of the same issues and this seemed to resolve the issue.
