wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2012-11-02T05:08:42+00:00
    I disabled WMM and have been running OK ever since on Netgear.
    Disable WMM (Wi-Fi multi-media) on your router
         a. Login to your NETGEAR router
         b. Go to 'QoS Setup' menu
         c. Uncheck 'Enable WMM' option to disable
         d. Click 'Apply' button
    Spoke too soon, still having issues.  WiFi dropped after about 2hrs.
