wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2014-11-09T21:01:55+00:00
    This CANT be marked as the "answer". This is a hardware issue so any early adopters of the Surface are screwed; MS messed they're just not admitting it.   Is the hope for MS just to hope that people think that it might be their wifi not an issue with the hardware?  Check tips on troubleshooting common wifi?  Seriously?  Come on MS you're better then that.
