Greetings all,
I had an issue this morning where Surface couldn't find any wifi networks (when 5 were in the area) and it was connected the previous night. I solved this issue by searching windows rt for Network. Open Network Connections, find the wifi device and then disable this connection. After a minute - I re-enabled the connection and then it started to work.
Nate
Greetings all,
Greetings everyone,
If following the steps in the provided links below fail to resolve your Wi-Fi issue I encourage you to create a new thread.
You will most likely have to do a REFRESH. Most of us has had to do that. For some reason or another the driver gets corrupted. You may also do a trick that most others have done as well as long as you don't have the 8.1 Preview of Windows 8 RT installed.
That trick is to open the Control Panel and go do Device Manager. Look for the Marvel WiFi adapter and "Uninstall" the driver but "DO NOT DELETE IT". When finished, reboot the tablet and it should connect.
Hello priscillaodendaal,
Let us know.
Best regards.
I bought a surface RT and got it home, set it up all was god and now my internet wont connect. At first it was saying that it had limited connectivity but now it wont let me see any wireless networks at all. It shoes the symbol for no data cable plugged in?
It looks like the wireless adapters are not working.
I updated everything yesterday and worked fine last night but no this morning.
thanks
Does your Wireless router SSID-name have special characters in it? Like !"#¤%&/() and so on. Even -_., can be a problem.
I know of someone with a Surface RT that had similar problem, WHO got it fixed by removing all the special characters.
There have been a firmware update for this issue. Perhaps that one have been installed on your Surface RT: http://www.microsoft.com/Surface/en-US/support/performance-and-maintenance/rt-update-history
