wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-07-03T11:38:29+00:00
    I also have the WRT160N router. Last year, I upgraded to a new version of the firmware so I think I have the last version (i'm now at work).
    I don't have the limited connection problem with my Surface. The only problem that I have now is that when I enable airplane mode and disable it after say a day, I don't have an internet connection. He says connected, no yellow limited connection symbol but no internet.
    I have to disable and enable the wifi adapter and reboot my surface to get the connection back... sometimes multiple times. Now I never use the airplane mode. In my holliday at the hotel, I didn't had that problem...
