wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-05-04T05:23:21+00:00
    I guess I should try again doing the driver uninstall.
    The good news is that I did this with the wired drivers and it seems to have fixed my wired connection. Since I did that the wired connection has been fairly stable, although I  can't say for sure since I haven't tried recently to transfer gigs of data on the lan.
    I will be away on business starting today so will get a chance to see how the wireless performs.
