wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2012-11-01T14:46:49+00:00
    I too have this problem on my Surface. Toggling Flight mode does fix it, but really having to do this every hour isn't really acceptable. Two other laptops that I have had for years on Win 7 do not show this problem with my network.
    Microsoft - please could you look into this issue and provide some feedback or a fix!
