wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2012-11-01T09:49:12+00:00
    My Surface suffers from the same. Connection time-outs while browsing, using the store, connecting to Xbox Live in games, in fact any apps that need an internet connection.
    I know it's not my router, my Lumia 800 right next to the Surface has no problems whatsoever.
    I really hope it's not a hardware issue.
