wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2012-11-01T04:41:27+00:00
    I believe this is a major bug. I have had the same problem. It has happened several times. MS needs to address this issue seriously.
    MS is lucky that Sandy captured the news the past few days. RT is a major turd.
    I took mine back because its possible this is a chip-set blunder and this first batch will never work right.
    It will certainly be more than 14 days before they get a fix.
    If its all patched up in a month I can always buy another one and I bet its cheaper.
    Thank you for your input. I would like to subscribe to your newsletter.
