wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-04-21T19:11:43+00:00
    SemperVirens1:
    Are you reverting the _surface_ to b, or the device you're connecting to (e.g. WAP or whatever)?  If it's the Surface you're reverting, how exactly do you do that?  That might be a useful interim solution for me.
