wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-04-14T11:37:44+00:00
    I only got my Surface this Friday, updated to latest patches, and after sleep WiFi will also NOT show any network. - Then when trying to shutdown it will hang and I have to give it a _hard_ reset.
