wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-04-12T11:20:28+00:00
    Eric,
    I have this problem as well.  Whenever I've had the issue, I hop into the Router Administration Page, and drop and renew the lease to the gateway.  Everyone else resets the issue from the Surface by cycling the Surface (Restart) so I started recycling the Router.  However, I found it easier (and shorter) to just drop and renew the lease to the gateway from the router.  This also solved the Limited Connectivity issue.
    I wonder then if there is a protocol error or other issue.
    Possible Workaround: As a workaround, people may be able to set their router lease to 20 or 30 minutes so that it cycles with the gateway before Limited Connectivity becomes an issue.  I will try this out.
    D.W.
