wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-04-12T04:18:09+00:00
    I just rebooted our Surface, checked the registry to ensure that the wi-fi settings were back to the default values, restarted again, crossed my fingers and connected to the network.
    It connected instantly. I did some high bandwidth things like streaming Netflix. No problems. I turned it over to my wife, and she's having no problems and says it's a lot faster.
    Oh, and the doorbell just rang, and it was the Devil. He handed me a pair of ice skates and said, "Grey, you may need these, it just froze over."
    Thanks for finally fixing this, at least on my system, Microsoft.
