wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-04-10T00:33:12+00:00
    I just updated my Surface RT with the April update, and was able to manually trigger the Limited issue like usual, simply by transferring a large amount of data over the network.
    I'm sorry, but it's absolutely ridiculous to have had 6 updates now, and still not be able to have this actually working.
    Perhaps something like 'it still doesn't work with Wifi Access Point X' might be a more useful post.
    We're way past that point.  Three or four months ago, sure... but when there's still a relatively widespread issue (across both of Microsoft's flagship devices, too) after all this time, that's not really going to do much.
    For what it's worth, my router uses Atheros wireless radios, which was mentioned before in the 51 pages of issues that people are having.
