wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2012-11-01T01:34:41+00:00
    Try enabling DHCP on the Surface and make sure DHCP is ON at the router too. What router model are you using?
    All my phones, TV, Blu-ray, ... don't have the issue.  For average consumers, this is really bad. Who knows what DHCP is.
