wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-04-09T23:37:45+00:00
    I just updated my Surface RT with the April update, and was able to manually trigger the Limited issue like usual, simply by transferring a large amount of data over the network.
    I'm sorry, but it's absolutely ridiculous to have had 6 updates now, and still not be able to have this actually working.
