wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-04-09T22:04:26+00:00
    It looks like my Limited wifi issue has been resolved after the April update.
    I have been using the Surface RT for a about an hour after the update and the issue didn't come back yet.
    Normally after each monthly update, Microsoft will change our manually adjusted wifi registry solution back to default which result Limited wifi. But this time after the update, my device stay on and stable. So i will see how it goes.
    Cheers
