wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-04-05T00:48:33+00:00
    My RT continues to be 'normal' after the February updates.  I have not had the limited connection issue on N or G or b/g/n access points like I did during January, and it was consistent during that time.  I've hopped around airports, hotels, home, hotspots and work on various AP's and haven't run into the limited connectivity - a couple APs at work being consistent problems in the past, are now working ok under various connection procedures (such as moving from home to work without doing anything, or moving between and restarting or going in and out of airplane mode, etc).
