Greetings all,
I had an issue this morning where Surface couldn't find any wifi networks (when 5 were in the area) and it was connected the previous night. I solved this issue by searching windows rt for Network. Open Network Connections, find the wifi device and then disable this connection. After a minute - I re-enabled the connection and then it started to work.
Nate
Greetings all,
Greetings everyone,
If following the steps in the provided links below fail to resolve your Wi-Fi issue I encourage you to create a new thread.
You will most likely have to do a REFRESH. Most of us has had to do that. For some reason or another the driver gets corrupted. You may also do a trick that most others have done as well as long as you don't have the 8.1 Preview of Windows 8 RT installed.
That trick is to open the Control Panel and go do Device Manager. Look for the Marvel WiFi adapter and "Uninstall" the driver but "DO NOT DELETE IT". When finished, reboot the tablet and it should connect.
Hello priscillaodendaal,
Let us know.
Best regards.
can't speak to the RT, but if you have a usb Ethernet adapter, that might work...works on the surface pro.
Also, you might try a usb wireless adapter.
specifically, I have had success with a d-link dwa 140 (wireless n, usb) and a startech usb Ethernet rj45 adapter. the startech is way cheap from Amazon.
Hope connecting solves your problem...the surface pro seems OK without help at this point (although the d-link usb wireless is faster than the built in).
