Greetings all,
I had an issue this morning where Surface couldn't find any wifi networks (when 5 were in the area) and it was connected the previous night. I solved this issue by searching windows rt for Network. Open Network Connections, find the wifi device and then disable this connection. After a minute - I re-enabled the connection and then it started to work.
Nate
Greetings all,
Greetings everyone,
If following the steps in the provided links below fail to resolve your Wi-Fi issue I encourage you to create a new thread.
You will most likely have to do a REFRESH. Most of us has had to do that. For some reason or another the driver gets corrupted. You may also do a trick that most others have done as well as long as you don't have the 8.1 Preview of Windows 8 RT installed.
That trick is to open the Control Panel and go do Device Manager. Look for the Marvel WiFi adapter and "Uninstall" the driver but "DO NOT DELETE IT". When finished, reboot the tablet and it should connect.
Hello priscillaodendaal,
Let us know.
Best regards.
My Surface RT was working fine for a couple of months, and I was happy with it. Then I went away for a week, came back and restarted it, and now it says it has "limited" connection to my home network, and won't connect to the internet at all.
I've read various threads on these and other forums about this problem, and am wondering what people suggest. I've tried toggling airplane mode on and off, forgetting the network and restarting, and various other suggestions. I obviously can't apply the latest updates because it won't connect to anything.
Needless to say, the MacBook and iPad sitting next to the RT on my desk (and other Win7 PCs in the house) can connect and are working fine... and for this reason I'm *not* willing to try taking the connection down from N to G on the router, because I need a decent network connection for work more than I need the Surface RT.
If anyone has any suggestions for other things to try (or even how to perform an update when you can't connect!) do let me know.
jt
