wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-03-29T18:41:49+00:00
    That is great.  Mine has been connecting quite often and I class it at 99.9% (I still have to give it a death threat and 1 reboot) but works quite well.  It is the handshaking with the Zoom router I have.  I tried it on a few others and it got right on and those were D-Link.
