wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-03-26T02:36:44+00:00
    Yea, it seems that everybody is having a slightly different problem on their machines.  D-Link devices are some of the best on the market and use a standard driver set that the system should have already in it.  I had thought of trying the USB LAN adapters and forgot to order one to test it.
    My RT tablet at times gets right online on first boot.  Other times, it takes all day to get it online at all.  In all instances, the internal adapter sees 5 bars for signal strength and I even checked that out by moving the tablet around to see if I get a signal loss.  So, I do believe that all of these tablets have good internal adapters and "something" else is causing an interference.  Probably why it is taking Microsoft so long to figure it out.
    Well, we have more updates coming up along with the Modern UI apps so hopefully the next batch of updates will fix these problems.  My tablet is going to be parked until there is a solution for it.
