wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-03-26T01:38:02+00:00
    can't speak to the others...my surface pro is using (right now) my d-link usb wireless adaptor and device manager sees exactly what it is...
    just switched over to a startech usb to gigabit Ethernet adapter...fired right up...
    so, at least two solutions pending a Microsoft fix
