wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-03-26T01:12:07+00:00
    Do watch out about the USB WiFi adapters.  The machine will recognize them but no driver.  The tablets do not have the generic driver set like in the full installation of Windows and you have to rely on drivers either from download or from a disc.  I tried two different adapters (Sabrent and Buffalo) for which even Linux recognizes and has drivers for and they would not work.
    I have not tried a USB RJ-45 LAN adapter and not sure if those would work at all.  Looks like you found one that works and it doesn't really matter how fast it connects as long as it does.  Remember, this is a tablet and not a gaming laptop or desktop.
    D-Link makes some pretty good devices and will order a few myself to test them.  Since Microsoft is dragging their feet in getting the WiFi issue corrected, looks like "we" in the community will have to find a solution.  Good job in trying it.
