wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-03-25T20:18:28+00:00
    There's another threat about limited connectivity issues...posted the following there:
    "I had a d-link dwa 140 sitting around (wireless n, usb)...for kicks, I plugged it in...works like a champ at 144 mbps...built-in usually at 58-65.
    No limited connectivity problems...seems a shame, but 3rd party adapter seems like a temporary work-around...at least till Microsoft solves this.
    The one I plugged in is somewhat large, but there are lots of mini adapters on Amazon...
    Curious if anyone has tried one..."
    this is a clunky kludge, of course, but it does work and seems to point to a complex of driver issues...zero problems connecting or with limited connectivity with that particular usb wireless adapter.
    If anyone has a different one sitting around, try it and let us know how it works...
