wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-03-22T06:46:23+00:00
    I have experienced this also on my Samsung Slate 7 running windows 7 and today on my Surface Pro.  I corrected this problem by going into the advanced power management and changing the wireless adapter to maximum performance on both devices and corrected the issue. I just went back and put my settings on my pro to maximum power savings and immediately limited came back changed it back to maximum performance and limited went away.
