wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-03-18T17:48:47+00:00
    I posted a possible work-around for the wifi issue on the Surface Pro thread, however, it might be worth a quick test for the Surface RT community.
    In my situation (Limited Connectivity issue with eventually losing Internet Access) following works now for 2 days (without certainly knowing if the issue just hides for now :-)
    go to Network and Sharing Center -> Advanced Sharing settings
    Then TURN OFF network discovery.
    From there on I can still access any of my network shares by name, I can insert USB sticks and any other USB stuff that triggers Win8 network operations, I can open any File Dialog without going into Limited status. Internet is certainly working as well. I have not done any router adjustments since it would not help in environments where I do not control the router.
    Above setting basically treats a homework like a public network and it has downsides, I know.
    However, if it helps more people than just me it can be a pretty clear pointer for MS. If not, ... well, then it was just a try.
    Frank
