wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-03-18T06:38:40+00:00
    I thought I had a breath of hope with the latest round of updates.  I dusted off my n router ready to go back to business like I'm in 2013.  Went a week without limited lockups.  I started noticing it was shutting down over night with errors to report.  Today I attempted to stream a YouTube video and back to the same old lockups.  Pathetic Microsoft, very pathetic.
