wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-03-18T05:55:43+00:00
    Greetings Grey,
    If you are experiencing an issue on a Non-Surface device that is using Windows RT or Windows 8, please post the issue in the corresponding Windows forum. Here is the link to the Windows forum.
    You can also bring up the issue with the manufacture of that particular device.
    I searched the Windows 8 forum for "wi-fi" and saw a number of people reporting connection problems, and all of them had "canned" responses from support. No one seems to be treating this as a widespread problem with Windows 8.
    My "particular device" had NO PROBLEMS with wi-fi under Windows 7. It has problems under Windows 8. Where do you think the problem is? With my device? I think not.
    If Microsoft wants to keep pretending this is only a Surface problem, that's their privilege. But when people ask me if they should upgrade their systems to Windows 8, I'll keep telling them that they should stay with Windows 7 if they need to rely on a wi-fi connection, until Microsoft gets their act together and fixes this problem.
