wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-03-16T18:53:40+00:00
    The registry fix has cured the disconnects and limited connection problems for me (RT 32GB model) completely. I only suffered when using wireless-n WAPs but we have a lot of those at work. Now I can roam seamlessly and it just works.
    However, I am surprised that Microsoft have not acted more decisively over these issues.
