wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-03-15T13:10:54+00:00
    Most likely the ISP is "throttling" the connection.  The Surface detects this and thinks you are on a pay-per-GB connection and only allows the most critical of updates pass through to try to save you money (such a thoughtful little device).  To change this setting:
    Settings Charm --> Change PC Settings;
    Devices, scroll to bottom on the right side and turn on:  Download Over Metered Connections.
    Remember to turn this setting off if you are using a hot spot or connection that is metered.
