wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-03-14T23:51:57+00:00
    I just installed an AirLink 101 AWLL5099 on my Gateway laptop and can now conenct to my Verizon hotspot. This does confirm, to me at least, that Windows 8 (NOT only Surface RT and Surface Pro) has problems with some wi-fi adapters.
    For the record, my Gateway has an Intel(R) Wireless WiFi Link 4965AGN.
    The Airlink reports that is is a Realtek RTL8188CU Wireless LAN 802.11n USB 2.0 Network Adapter
    I would recommend that anyone who is experiencing connectivity problems with Windows 8 on a non-Surface machine post the information on their network adapter. That might help Microsoft narrow the problem down.
    Open the file explorer
    Right click on Network and Select Properties
    Click on Change Adapter Settings
    Right click on the adapter icon and select Properties
    Copy the information from the Connect using field
    And id anyone knows of a USB wireless 802.11n adapter that will work on a Surface RT, please post it here!
