wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-03-14T21:16:44+00:00
    Greetings everyone,
    Sorry to hear that the March firmware did not resolve the Limited WiFi issue. Continued wireless updates are planned in coming months, please keep checking Windows Update during the next Patch Tuesday cycle.
    Also, please keep this thread to Surface RT Limited WiFi issues. If you have a Surface Pro and are experiencing Limited WiFi, please post HERE so we can better track the issue.
