wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-03-14T19:54:20+00:00
    Additionally, I heard an interesting story from a colleague of mine: He experienced the very same limited connection issue on a brand new Sony laptop (Centrino WiFi) with Windows 8 yesterday. What he told me was exactly the same story as with the Surface.
    A coworker of mine told me today that her Dell Windows 8 laptop is doing the same thing, actually.
    Yes, I too have heard from folks using win8 (non surface devices). Looks like MS is digging in a wrong hole here :) . My be there is some problem with win8 network stack itself.. go figure.
    By the way, I have installed march updates on my RT and only saw the "Limited Connectivity" issue once from past one day. So, I can say the update really didn't fix it, but looks like it reduced the frequency atleast.
    History wise, my device was working without any issues (ie no wifi issues) before February updates. After feb updates wifi is crazy which made me not to use this device much for last one month.
    Now waiting for April updates, and hopefully current update at least is not as crazy as the previous one.
