wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-03-13T20:25:41+00:00
    Additionally, I heard an interesting story from a colleague of mine: He experienced the very same limited connection issue on a brand new Sony laptop (Centrino WiFi) with Windows 8 yesterday. What he told me was exactly the same story as with the Surface.
    A coworker of mine told me today that her Dell Windows 8 laptop is doing the same thing, actually.
