wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-03-13T20:00:39+00:00
    Could someone reiterate the registry fix? Does this work for Surface Pro? The one registry fix I have seen posted leads me to a place in the registry where there are no matching keys for what is described.
    My RT is still working after the recent updates. Wrt the registry fix: that did not have any effect in my case, but I think you should give it a try, because it seems to work sometimes.
    Additionally, I heard an interesting story from a colleague of mine: He experienced the very same limited connection issue on a brand new Sony laptop (Centrino WiFi) with Windows 8 yesterday. What he told me was exactly the same story as with the Surface.
