wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-03-13T19:39:46+00:00
    Surface Pro here. The recent firmware fix did nothing for me, either. It might possibly be worse than before. Now when I am connected, the connection works very slowly, and I know this is unique to the Surface because my iPad is zippy as ever.
    Could someone reiterate the registry fix? Does this work for Surface Pro? The one registry fix I have seen posted leads me to a place in the registry where there are no matching keys for what is described.
    Has anyone else had trouble with the surface support site. I was able to get in before and got a replacement Surface Pro sent out, but now when I go to surface.com/support and choose my registered device, the drop-down for "Choose a Topic" has no entries and "Choose an issue" is greyed out. If I generically choose the Surface Pro I can get through that part, but then it asks for the serial number and just loops me back to the first page.
