wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-03-13T16:03:32+00:00
    Another firmware update, and the problem is still there. Registry patch re-applied.
    I ordered an AirLink101 AWLL5088 Wireless N 150 Ultra Mini USB Adapter as recommended in another post. I'm hoping that will bring me back to the N band.
