wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-03-13T14:56:01+00:00
    Check thermals, This reply really goes for everyone but my last surface pro had this issue, however it also had an issue with heat, ie it would sit idle on a desk running 50+ browsing the net it would push temps up to 65,
    after changing out my unit I have not experienced this issue at all, it is entirely possible a failsafe is beeing tripped by the wlan card overheating causing it to shut down, (which in turn causing windows to reboot the drivers) leading to limited connection before the chip heats up again and restarts the cycle
