wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-03-12T22:47:33+00:00
    Well, having just updated my Surface RT (which I rarely use anymore, in favor of the Pro), and rebooted a few times, so the firmware update has definitely been applied....  I just got the limited connectivity issue again.
    Here's hoping it was a fluke.
    Edit:  And again, while transferring a file over the local network.  In other words, decidedly NOT fixed for me.
