wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-03-11T20:50:20+00:00
    Do not presume anyone reporting their unit behaving normally is jumping to conclusions.
    Mine is now working again for about two weeks, and I have pushed through about five gigs since then. According to netsh wlan show interfaces, the device is working in N mode. The thing I really dislike is that  there is absolutely no reason (i.e. patch) for that it is working again... The error is absolutely byzantine and I fear that it will come back some day.
